Help on Using World map plugin
    Grafana v8.2.5 (b57a137acd) using browser.
    OS: windows 10
    I’m trying to show on the map a few points of interest for me as they change boolean value (true/false) and color ofcourse.
    I have a .json file with the coordinates for the points of interest and I don’t understand where to put it. aswell, I have the boolean data using InfluxDB
  • What happened?
    nothing because I don’t understand how to integrate the .json file and the InfluxDB data.
    I expected the plugin would be easier to use and to be able to see the data of points of interest on the map. I’m new to this.
    nothing which I noticed.
    [Question] worldmap general question · Issue #47 · grafana/worldmap-panel · GitHub
welcome to the :grafana: forum, @lnx
A few things. Don’t use the Worldmap panel. Use the Geomap panel. Geomap replaced Worldmap in Grafana 8.
There are a number of ways to mock up data from a static json file. try using the JSON API plugin:
This is also a good place to start if you are new to grafana: Grafana fundamentals | Grafana Labs
