I am using Alloy to collect logs from multiple services on a single Windows server.
The logs are organized in the following folder structure:
G:\Services\Background\\logs\<log_file>.log
Example paths:
G:\Services\Background\ServiceA\logs\default.log
G:\Services\Background\ServiceB\logs\default.log
G:\Services\Background\ServiceC\logs\default.log
I want each log sent to Loki to have a dynamic label service based on the folder name.
Currently, all logs appear in Loki with:
service_name = unknown_service
My current config.alloy:
loki.write "endpoint" {
endpoint {
url = "http://loki-server:3100/loki/api/v1/push"
local.file_match "service_logs" {
path_targets = [{
"__path__" = "G:\\\\Services\\\\Background\\\\*\\\\logs\\\\*",
sync_period = "60s"
loki.source.file "sendlogs" {
targets = local.file_match.service_logs.targets
forward_to = [loki.process.parse_service_logs.receiver]
loki.process "parse_service_logs" {
forward_to = [loki.write.endpoint.receiver]
stage.multiline {
firstline = "^\\["
stage.regex {
source = "filename"
expression = "Background\\\\(?P<service>[^\\\\]+)\\\\logs.*"
stage.labels {
values = {
"job" = "service_logs",
"hostname" = sys.env("HOSTNAME"),
"service" = "{{ .service }}",
What I have tried:
Using
stage.regexwith__path__→ did not work on Windows, always returnsunknown_service. -
Using
stage.regexwithfilename→ still did not work, all logs remainunknown_service. -
Using
stage.regexwithmessage→ works for some Windows Event logs but not for file logs.
Goal:
Extract the service name dynamically from the folder name and send it as a service label to Loki.
I want a single Alloy configuration that works for all services under G:\Services\Background\<SERVICE>\logs without installing one Alloy instance per service.
Can anyone advise on the correct way to configure Alloy on Windows to dynamically extract the service name from each folder and send it as a label to Loki?
