I’d like to know if there’s a way to not repeat myself. I have a folder /var/log/pantheon
. Inside that an rsync job will drop log files for multiple Pantheon sites, each under it’s own folder. Within each of those sites is an NGINX log folder and a PHP log folder.
The environment
label will be static since this Alloy instance will only process logs for staging
. However, I want to make sure each log file is correctly labeled by service. Right now I have a a static label being set by matching the file path.
As you can see, I am repeating the stage.match
block several times. One for each service. Is there a better way? Could I do a regex capture from the log file’s path and use that value as the service name?
Alloy potential configuration file (untested):
local.file_match "local_logs" {
path_targets = [
{"__path__" = "/var/log/pantheon/**/php/*.log"},
{"__path__" = "/var/log/pantheon/**/nginx/*.log"},
sync_period = "500s"
loki.process "labels" {
stage.static_labels {
values = {
environment = "staging",
stage.match {
selector = "{filename=~\"/var/log/pantheon/service_name_abc/.*\"}"
values = {
service_name = "service_name_abc",
stage.match {
selector = "{filename=~\"/var/log/pantheon/another_service/.*\"}"
values = {
service_name = "another_service",
stage.match {
selector = "{filename=~\"/var/log/pantheon/xyz_service/.*\"}"
values = {
service_name = "xyz_service",
stage.match {
selector = "{filename=~\"/var/log/pantheon/yet_another_one/.*\"}"
values = {
service_name = "yet_another_one",
forward_to = [loki.write.grafana.receiver]
