Help: error " Cannot read property 'result' of undefined"
Hi, hope i can find answer here.
I’m using prometheus+grafana to monitor my system. It ran well before today. In the morning, I find grafana cannot show data/trend. On each panel ,there is one red “!” and the erros msg is that " cannot read property ‘result’ of undefined". I didn’t make any change on prometheus and grafana! It just happend.
At this time, prometheus works well. I can search the tag and get the trend in prometheus.
The version of prometheus is: 2.0.0, and grafana is 4.6.2.
Can anyone help?
Thanks a lot.
In firefox, the error msg is " t.data.data is undefined.
Anyone can help?
Can you show your query? Does this query work in prometheus native dashboard?
The query is very simple, just the variable name. And in prometheus native dashboard, I can get the value and trend without error.
There are some error msg:
TypeError: Cannot read property ‘result’ of undefined
at http://192.168.0.102:3030/public/build/0.be20b78823b4c9d93a84.js:7:141291
at l
Try to look at network query result in browser devtools, maybe you’ll see problem in the response.
