I have a MYSQL query that is referenced to a template variable. When the variable returns null, the mysql query fails since the IN clause contains an empty list. How do we handle such a scenario.
You can write CASE statement in your query .
Actually you cannot use CASE - Grafana does direct substitution on template variables. If no values are returned from variables, it ll be blank. So CASE or COALESCE canât be used in this situation.
You can resolve this issue using the following
WHERE id IN (${id:sqlstring}+'');
Also ran into this issue when using Loki, When I wanted no results returned when nothing was selected
|~ "${id:regex}|EMPTYDEFAULTVALUE"
It would be nice to add a filter to provide a default value
The WHERE id IN (${id:sqlstring}+''); solution above started to fail me in certain situations.
A much better solution is WHERE FIND_IN_SET(id, '${id:csv}')
I faced the same issue and this is how I resolved it:
Lets say your template variable is A
Lets say the condition when your template variable returns nil is Cond1
Use:
WHERE NOT (cond1 AND parameter in $A)
This way, when cond1 is not true and A is going to be empty, the bracket of AND does not work.
If suppose you have multiple template variables A,B,C and they DONT return empty during conditions CondA,CondB and CondC respectively,
Eg. during CondA, $A is definitely not empty but if CondA is not satisfied, A may be empty.
This will fail: WHERE parameter in ($A,$B,$C)
This will work:
WHERE
(condA AND parameter in $A) OR
(condB AND parameter in $B) OR
(condC AND parameter in $C)
Howdy,
Issue:
When no options are selected from a variable list or a variable text box the $variable returns a blank statement as opposed to Null. This results in the user not being able to use try-catch blocks, if then, or case statements.
Workaround:
create a new variable using the original variable to search your database. This will generate a None value type if the db query returns none. You can then use the new variable in your query along with standard sql case, if-then, etc statements
Example variable query:
select * from TABLE if COLUMN in $variable
If your $variable is empty the result of the query will be None
the easiest way to do this would be to use a union and pull in a default value.
select data from table where condition of ${variable}
union select âno_data_foundâ as âno_dataâ ;
or something like that.
That way even if your variable query did not return and results at least the âno_data_foundâ option would be available, and it could point to an empty data set or something to keep the dasbhoard working.
Unfortunatelly nothing metioned worked good for me, so I have come up with this solution:
I have this query to get the variable:
select vhost from celery.events
WHERE
$__timeFilter(time_local)
group by vhost
order by vhost
I have set
Custom all value
to 'default'
then added to my code that checks if the variable is actually âdefaultâ and then TRUE, otherwise use the âinâ clause. This way setting custom all value does not disable the all default behaviour.
Condition:
CASE WHEN $vhost = 'default' THEN TRUE
ELSE vhost in ($vhost) END
Although late, I want to share my solution. The problem is, that in this case the variable query returns an empty table, i.e. not NULL, nor an empty string. Therefore, you can solve this issue by returning NULL, if the table is empty. I found the solution here:
I added some comments since the query wasnât clear for me at first.
with BaseData as (
SELECT name FROM myTable
SELECT * FROM BaseData -- normal case, i.e. BaseData is populated
UNION ALL
SELECT BaseData.* FROM (SELECT 1) -- get the same structure as BaseData
LEFT JOIN BaseData ON false -- always false, so every field is NULL
WHERE NOT EXISTS (SELECT 1 FROM BaseData) -- apply in cases when BaseData returns an empty table
