Hello. I need help and I can’t figure out how to resolve the issue. I would appreciate your help. I have data that prometheus takes every 10 hours from my exporter connected to api service that collects data once at the beginning of the day, for the previous day. I get some data. I want to combine the data for the day into one single number and shift the data back, I learned the shifts, but I can’t collect the data, I get a lot of points on the chart, but I only need one per day, and I could set the number of days, and he told me Would give out for each day, only one record. Thank you
What happened?
