Group/tag values in a multi-value template variable without a query
I have a Cloudwatch data source and I would like to group/tag values in a multi-value template variable I created. Can I somehow specify constant group/tag names in the “Tags query” field?
Regards,
Tobias
Hi Tobias,
I have a similar issue, were you able to get a solution to your problem? If so, could you tell me what you find?
Unfortunately, no.
Regards
Tobias
