Group by transformation breaks when changing variable values.
Grafana v10.2.2 -
Bar Chart Panel where total is grouped by time
this is working fine
- What happened?
when I change the variable filter:
Sure I can fix it, by setting up the correct calculation again, but this would mean, everytime I change the variable filter, I have to also edit the panel to correct the calculation:
