Hi all! I am trying to display the duration of all runs grouped by months, but when I try to use this qeury, the bars don’t have month number, it is only displayed in the legend.
I know that I can select the field I want to be shown as well, without using GROUP BY, but in this case I can’t use SUM() because Influx doesn’t support aggregated and non-aggregated functions togather.
My scheme:
fieldKey fieldType
duration integer
month string
tagKey
id
platform
project_name
tag_month
year
9.4.2 -
I want to display duration of all runs for aech month. -
I am using GROUP BY and selecting two fileds togather. but this doesn’t work -
What happened?
4:00 is displayed under all bars -
I expect month to be displayed under each bar instead of “4:00” -
SELECT sum(“duration”) / 60 from “$project-testRun-duration” WHERE (“year” =~ /^$year$/) GROUP BY “tag_month”
SELECT “duration” / 60, “month” from “$project-testRun-duration” WHERE (“year” =~ /^$year$/) -
Nope -
Nope
