v8.1.1 and v7.3.7 -
data visualization using gauge and thresholds in panel. -
Gauge with thresholds working correctly with v7.3.7 but the same dashboard migrated to v8.1.1 the thresholds are not working as expected. -
What happened?
v8.1.1 is not able to apply the threshold over gauge type cell display mode. -
thresholds to work properly on gauge type cell display mode. -
yes, attached screenshot.
Grafana v8.1.1 column and override configuration:-
Grafana v7.3.7 column and override configuration:-
Image Grafana v7.3.7 shows the column ‘Connect Rate’ displayed as unit percent (0-100) with mode LCD Gauge and threshold applied on the values to show progress.
The same dashboard then imported in another instance of Grafana with version v8.1.1 with no change in dashboards, data source, the applied configuration of unit, cell display mode with threshold is not working on the column ‘Connect Rate’.
