- Firefox 146.0.1 (64-bit) and Grafana 12.4.0-20837123516
- Best implementation of dashboard with multiple panels using grafanacloud-infinity as the data source with a URL CSV providing the data.
- Does it matter if I have multiple Time Series panels referencing the same URL CSV for data or should I have one large Data Table panel referencing the URL CSV data and have the Time Series panels reference that Data Table panel?
- NA, still developing the dashboard so it’s got a small slew of copy paste errors, but I could throw a link to it in here if needed.
What happened?
- Firefox throws messages about the webpage slowing down firefox
- NA
- No errors, but Firefox throws messages about the webpage slowing down firefox
- No, couldn’t find any recommendations specific to this
How big is the csv? It does have limitations
