Could someone please help me, I am facing below error of “Cannot authentificate admin user in LDAP” while configuring ldap with grafana. I have enabled it from /etc/grafana/grafana.ini from auth.ldap section. I have also put filters = ldap:debug.
t=2020-05-14T11:14:03+0200 lvl=info msg=“LDAP enabled, reading config file” logger=ldap file=/etc/grafana/ldap.toml
t=2020-05-14T11:14:10+0200 lvl=eror msg=“Cannot authentificate admin user in LDAP” logger=ldap error=“Invalid Username or Password”
t=2020-05-14T11:14:10+0200 lvl=eror msg=“No user was found in the LDAP server(s) with that username” logger=context userId=1 orgId=1 uname=admin error=“Invalid Username or Password” remote_addr=x.x.x.x
t=2020-05-14T11:14:10+0200 lvl=info msg=“Request Completed” logger=context userId=1 orgId=1 uname=admin method=GET path=/api/admin/ldap/test status=404 remote_addr=10.71.4.196 time_ms=9 size=72 referer=https://x.x.x.x:3000/admin/ldap
my sssd file looks like below. The point here to note is the communication is happening with tls and cert file is provided /etc/ipa/ca.crt thats why I also mentioned it in grafana.ini as root_ca_cert.
Hello All ,
I have the same error when i try to connect to ldap with admin :
t=2022-01-03T14:52:54+0100 lvl=eror msg=“Cannot authenticate admin user in LDAP” logger=ldap error=“invalid username or password”
t=2022-01-03T14:52:54+0100 lvl=eror msg=“No user was found in the LDAP server(s) with that username” logger=context userId=1 orgId=1 uname=admin error=“invalid username or password” remote_addr=X.X.X.X
t=2022-01-03T14:52:54+0100 lvl=info msg=“Request Completed” logger=context userId=1 orgId=1 uname=admin method=GET path=/api/admin/ldap/admin status=404 remote_addr=X.X.X.X time_ms=136 size=72 referer=http://myserver:3000/admin/ldap
this my config :
[[servers]]
Ldap server host (specify multiple hosts space separated)
host = “myldap_server.com”
Default port is 389 or 636 if use_ssl = true
port = 10389
Set to true if ldap server supports TLS
use_ssl = false
set to true if you want to skip ssl cert validation
