We upgraded grafana from 8.3.4 to 9.3.1 on GKE and all the alerts setup for prometheus datasource dashboard started to trigger false alerts with: #12280: [FIRING:1] DatasourceError Alerting (alert msg..). Is there some details on how to get around this issue so that we can upgrade without triggering all the alerts that’s configured in prometheus backed dashboards?
v8.3.4 upgrading to v9.3.1 on GKE 1.21.14-gke.3000 with Postgresql 10 backend -
We are trying to upgrade grafana v8.3.4 to v9.3.1 -
In the StatefulSet for grafana, change:image: grafana/grafana:8.3.4toimage: grafana/grafana:9.3.1 -
What happened?
Alerts configured for dashboards with prometheus datasource started to trigger:
#12280: [FIRING:1] DatasourceError Alerting (alert on monitoring) -
We expected to not get the “DatasourceError” alerts for all the alerts that are configured for prometheus backend dashboards. -
I followed this instruction. The only change that was made was to upgrade our Postgres from 9.6 to 10, before upgrading to grafana 9.3.1
