Grafana using Socks5 proxy with Vertica datasource - not working
    10.1.1
    connect to a Vertica Server behind a proxy (Keys are enabled externaly)
    using the Grafana.ini configuration:
#########. Secure Socks5 Datasource Proxy ####################
[secure_socks_datasource_proxy]
enabled = true
; root_ca_cert = /etc/ca.crt
; client_key = /etc/client.key
; client_cert = /etc/client.crt
; server_name = proxy.grafana.svc.cluster.local
The address of the socks5 proxy datasources should connect to
proxy_address = localhost:10020
show_ui = true
  • What happened?
no connection in done, no Log is created
connect to a Vertica DataSource configured behind a Proxy
copied: see aboive
no logs created on the requested connection
tried the following Connection:
not sure if the Vertica is Supported according to:
