Wonder if anyone will reply as the are way to many unanswered posts here.
Per grafana-toolkit, my code no longer will build, the other rpm tasks work fine, but build never ends
It stops at “Compiling…” Any ideas?
> grafana-toolkit plugin:build
✔ Preparing
✔ Linting
No tests found, exiting with code 0
✔ Running tests
⠙ Compiling... Starting type checking service...
Using 1 worker with 2048MB memory limit
⠦ Compiling...
Hash: 117890807e27d4f95605
Version: webpack 4.41.5
Time: 7534ms
Built at: 11/09/2020 5:29:57 PM
Asset Size Chunks Chunk Names
LICENSE 11.1 KiB [emitted]
README.md 1.2 KiB [emitted]
img/logo.svg 1.55 KiB [emitted]
module.js 401 KiB 0 [emitted] [big] module
module.js.LICENSE.txt 1.42 KiB [emitted]
module.js.map 1.38 MiB 0 [emitted] [dev] module
plugin.json 784 bytes [emitted]
Entrypoint module [big] = module.js module.js.map
[0] ../node_modules/moment/moment.js 147 KiB {0} [built]
[1] ../node_modules/@microsoft/signalr/dist/esm/ILogger.js 1.47 KiB {0} [built]
[3] ../node_modules/@microsoft/signalr/dist/esm/Errors.js 3.25 KiB {0} [built]
[4] external "react" 42 bytes {0} [built]
[5] external "@grafana/data" 42 bytes {0} [built]
[7] ../node_modules/@microsoft/signalr/dist/esm/HttpClient.js 1.88 KiB {0} [built]
[8] ../node_modules/@microsoft/signalr/dist/esm/Loggers.js 667 bytes {0} [built]
[9] ../node_modules/guid-typescript/dist/guid.js 1.92 KiB {0} [built]
[11] external "@grafana/ui" 42 bytes {0} [built]
[12] ../node_modules/axios/index.js 40 bytes {0} [built]
[13] external "rxjs" 42 bytes {0} [built]
[152] ../node_modules/axios/lib/axios.js 1.39 KiB {0} [built]
[171] ../node_modules/numeral/numeral.js 32.8 KiB {0} [built]
[178] ../node_modules/@microsoft/signalr/dist/esm/index.js + 14 modules 141 KiB {0} [built]
| ../node_modules/@microsoft/signalr/dist/esm/index.js 940 bytes [built]
| ../node_modules/@microsoft/signalr/dist/esm/DefaultHttpClient.js 2.28 KiB [built]
| ../node_modules/@microsoft/signalr/dist/esm/IHubProtocol.js 1.69 KiB [built]
| ../node_modules/@microsoft/signalr/dist/esm/Subject.js 1.33 KiB [built]
| ../node_modules/@microsoft/signalr/dist/esm/HubConnection.js 46.3 KiB [built]
| ../node_modules/@microsoft/signalr/dist/esm/ITransport.js 1.38 KiB [built]
| ../node_modules/@microsoft/signalr/dist/esm/JsonHubProtocol.js 4.84 KiB [built]
| ../node_modules/@microsoft/signalr/dist/esm/HubConnectionBuilder.js 5.42 KiB [built]
| ../node_modules/@microsoft/signalr/dist/esm/XhrHttpClient.js 3.75 KiB [built]
| ../node_modules/@microsoft/signalr/dist/esm/DefaultReconnectPolicy.js 859 bytes [built]
| ../node_modules/@microsoft/signalr/dist/esm/HttpConnection.js 37.7 KiB [built]
| ../node_modules/@microsoft/signalr/dist/esm/LongPollingTransport.js 15.3 KiB [built]
| ../node_modules/@microsoft/signalr/dist/esm/ServerSentEventsTransport.js 8.44 KiB [built]
| ../node_modules/@microsoft/signalr/dist/esm/WebSocketTransport.js 9.99 KiB [built]
| ../node_modules/@microsoft/signalr/dist/esm/AbortController.js 1.29 KiB [built]
[179] ./module.ts + 8 modules 37.9 KiB {0} [built]
| ./module.ts 296 bytes [built]
| ./DataSource.ts 3.78 KiB [built]
| ./ConfigEditor.tsx 2.27 KiB [built]
| ./QueryEditor.tsx 7.27 KiB [built]
| ../node_modules/tslib/tslib.es6.js 10 KiB [built]
| ./shared/processThisApiClient.ts 1.98 KiB [built]
| ./shared/dataSetConnection.ts 7.68 KiB [built]
| ./shared/errorModel.ts 528 bytes [built]
| ./shared/structure.ts 4.09 KiB [built]
+ 165 hidden modules
✔ Compiling...
