I am operating several K8s Clusters.
To collect logs, expose Loki’s endpoint as Ingress to the central Kubernetes Cluster, and use the endpoint in the distributed cluster’s Promtail.
Can Tempo have a configuration like this?
Ingress value does not exist in grafana/tempo helm chart.
grafana/tempo-distributed helm uses ingress on tempo gateway. Can Query Endpoint and OTEL Exporter Endpoint be used through the unified port of this gateway?
Or what’s the best way to use Grafana Tempo and Loki in a multi-cluster environment?
