Grafana tables influxdb source and summing data
Hi
Working on a Table Dashboard accessing InfluxDB (1.1) with grafana 5
I have a measurement “info” in which I have imported data with the following fields -
Duration Field1 Field 2
40 123 444
10 111 333
10 123 333
10 90 222
10 111 222
What I;ve been asked is to provide a view which shows the total Duration sorted by Field 1
So
Total Duration Field1
50 123
20 111
10 90
and so on
I’m at a loss to work out how to initially approach this - is it something I can do in Grafana or something I need to do first in influx ?
Thanks
(sorry for the edit - his save by mistake)
Ok its quite simply an InfluxDB query using
select sum(“DURATION”) from “info” group by “FIELD1”
