Grafana support for repeated alert notifcation
I had a question about the Grafana road map for the alerting API. Currently Grafana only supports alerting once per change in state. Is there a plan to support notifications for every n number of evaluations of the alert where the alert threshold has been triggered? I am happy to create either a plugin or issue/pull request on Github for this as I will need this functionality. I have not seen any plans to support this but wanted to check with the community to see if this is in progress. Thoughts?
I found an issue tracking this feature that did not come up on my first search. For anyone who comes across this, here is the link: https://github.com/grafana/grafana/issues/7330.
