Hi Team,
I came across one scenario of sorting and am not sure how to achieve this. Can someone please help?
I have a Prometheus query for the Panel, which shows the latency value in Gauge unit- seconds (s)
max_over_time(max by(name)(histogram_latency_seconds{Label=“$label”,quantile=“$Quantile”, env=“u”at,from=“kafka_phlegethon”})[$__range:$__interval])
Also, this panel is repeated based on the Label. I need to sort these all panels by their value. Is that doable?
Thank you!
