Grafana-server can't be started by unknown reason
Hi. After I installed grafana-image-renderer plugin with Grafana CLI.
grafana-server service can’t be started by unknown reason. The error message is “permission denied”. But permission seems to be OK.
Could you please tell me what is the problem?
Thanks for any help or pointers.
grafana-server 7.5.11 on Oracle Linux Server 8.6
grafana-server service start
What happened?
First, grafana-server service could be started. But it couldn’t be started by unknown reason after I installed grafana-image-renderer plugin with Grafana CLI.
“permission denied” was written in grafana.log. But permission seems to be OK.
No config change
“permission denied” was written in grafana.log. But permission seemed to be OK.
No
/var/log/grafana/grafana.log
t=2022-XX-XXT16:25:27+0900 lvl=eror msg="Stopped RenderingService" logger=server reason="Failed to start renderer plugin: fork/exec /var/lib/grafana/plugins/grafana-image-renderer/plugin_start_linux_amd64: permission denied"
t=2022-XX-XXT16:25:27+0900 lvl=info msg="HTTP Server Listen" logger=http.server address=[::]:3000 protocol=http subUrl=/grafana socket=
t=2022-XX-XXT16:25:27+0900 lvl=eror msg="A service failed" logger=server err="Failed to start renderer plugin: fork/exec /var/lib/grafana/plugins/grafana-image-renderer/plugin_start_linux_amd64: permission denied"
t=2022-XX-XXT16:25:27+0900 lvl=eror msg="Server shutdown" logger=server reason="Failed to start renderer plugin: fork/exec /var/lib/grafana/plugins/grafana-image-renderer/plugin_start_linux_amd64: permission denied"
/var/lib/grafana/plugins/grafana-image-renderer/ permission
 -rw-r--r--. 1 grafana grafana    15277 Jun XX 08:42 CHANGELOG.md
 drwxr-xr-x. 7 grafana grafana     4096 Jun XX 08:42 chrome-linux
 drwxr-xr-x. 2 grafana grafana       22 Jun XX 08:42 img
 -rw-r--r--. 1 grafana grafana    11341 Jun XX 08:42 LICENSE
 -rw-r--r--. 1 grafana grafana    16021 Jun XX 08:42 MANIFEST.txt
 -rw-r--r--. 1 grafana grafana      798 Jun XX 08:42 plugin.json
 -rwxr-xr-x. 1 grafana grafana 67693961 Jun XX 08:42 plugin_start_linux_amd64
 -rw-r--r--. 1 grafana grafana     4369 Jun XX 08:42 README.md
Hi @gont,
Welcome to the :grafana: community forum !!
Not sure if you are still having this issue or already resolved it.
You can have a look at the documentation on how to troubleshoot the Image rendering plugin.
Troubleshoot image rendering | Grafana documentation
