Grafana Server and Microsoft Graph using Infinity data source
Hi Grafana Community,
Is there a document I can follow on how to get the Infinity data source working with Microsoft Graph?
I want this to work:
https://graph.microsoft.com/v1.0/admin/serviceAnnouncement/healthOverviews?$select=service,status
Thank you in advance!
-Andrew
Data source config:
Explore:
I figured it out:
Authentication: OAuth2
Grant type: Client Credentials
Scopes: https://graph.microsoft.com/.default
Here is the trick:
add Endpoint param resource with value https://graph.microsoft.com
