Hello, i am actually use grafana version 10.0.2 with prometheus versions prometheus latest version v2.48
i am currently install both of them with podman inside a containers. I’m trying to provisionning my datasource prometheus and all my exported dashboard from another Grafana instance. in my dashboars i use variables , so when i use provisionning for my dashboard i got errors:
- i got Bad Gateway when i want to add new connections from menu is maybe caused because i am in offline environnement.
2 . Second error
i got error templating due to variable DS_Prometheus not found i changed all the DS_PROMETHEUS by the id of my dashboard Prometheus then i got this error
dashboard conf files
apiVersion: 1
providers:
- name: dashboards
type: file
editable: true
updateIntervalSeconds: 30
options:
path: /etc/grafana/provisioning/dashboards/
foldersFromFilesStructure: true
datasources conf files
apiVersion: 1
deleteDatasources:
- name: ‘Prometheus’
datasources: - name: Prometheus
type: prometheus
access: proxy
url: http://url:9090
basicAuth: false
readOnly: false
isDefault: true
