Grafana Postman collection and more
Hi guys,
I couldn’t find any collection ready available for the grafana api, so I went ahead and made one.
If you might find it useful, you can find it here:
The collection is made for the vscode extension thunder client, but it is also exported in postman format v2, and i m planning to add a version for the rest client extension as well.
Have a good one!
gjed
Hi @gjed ,
Well I also bumped into this one 2 days a go and found this link (as not officially maintained by us) which seems to be working (did not try each of them :slight_smile: )
Hope this helps !
Acutally, a couple days later after posting, I found out you can just import the openapi definition in postman and you’re ready to go (like the one from play.grafana.org: https://play.grafana.org/public/api-merged.json).
Might just do a pharser from openapi to the Rest vscode client so the circle is closed
gjed
awesome, thanks! I use insomnia and was able to import it directly from URL
Tried this, some minor changes needs to this like adding api , {{baseUrl}}/api
