When routing my plugin’s HTTP’s requests through the data proxy, the request path is being double encoded. I confirmed this looking at the following logs:
In the frontend I’m calling a URL ending with “/Our devices”, which is expectedly converted to “/Our%20devices”. However the Grafana backend is encoding it again, which changes the path to “/Our%2520devices” which is not an expected value by our API. Is this expected behaviour? Is there a way to avoid the second encoding?
Hi @pedro19f1 I checked the backend code that handles the urls sent to the data proxy and we are not doing any encoding of the url (at least not that I can see. maybe I missed it)
My advice is, double check what you are sending, try for example to encode the url parameters in the frontend instead of letting the browser encoding them for you.
If ultimately you can’t find a way to make your case work and you are convinced this might be an error in Grafana please open an issue reporting a bug but be sure to provide us with a code repository we can easily clone and replicate the issue so we can fix this problem faster.
