Hi all,
I just installed Grafana on my Raspberry Pi Zero, following instructions here : https://github.com/fg2it/grafana-on-raspberry/wiki and choosing the version for raspberry 1.
At this point the installation went just fine. I started the grafana-server service but i can’t connect to the http port 3000.
I’ve enabled the http protocol and the port 3000 in the config file :
[server]
Protocol (http, https, socket)
protocol = http
The ip address to bind to, empty will bind to all interfaces
;http_addr =
The http port to use
http_port = 3000
As I thought it would certainly be needed, I have no grafana.log file in /var/log/grafana/
So if anyone can help it would be really appreciated
Thanks
