I am looking for a solution that attach the infinity data source table data as a CSV file to Alerts when they gets triggered.
Is there a way to achieve this ?
Any help would be highly appreciated.
Regards
Lakshay
Regards
Lakshay
From what I know, I don’t think it’s possible, attaching a file to an alert notification.
Though it’s not suggested and if you still want it, maybe you can print those data as label values and then use alert templating to write your custom go template to print them in readable manner.
I still suggest creating a dashboard that displays this table based on triggered values and embedding that dashboard URL in alert.
