Grafana version is 9.5
OS Windows 8 -
Calculate the elapsed time since containers started. -
Using metricscontainer_start_time -
What happened?
container_start_timeis returning a timestamp. On converting theValuefield toTimeunit, Grafana is miscalculating it as 20 Jaunuary 1970. -
Grafana should calculate correct time from timestamp coming from Prometheus. -
An example timestamp: 1658903170
On converting to time usingConvert field typetransformation: 1970-01-20 10:18:23.170 -
No errors noticed -
NA
Can you use the data tab inside the Grafana Inspector panel to share your data?
the raw data is what we need to try and mock up your problem ![]()
