Grafana metrics into prometheus
Fellas,
I am using Helm to install Grafana and Kubernetes. How can I get the Grafana internal metrics to be pushed into prometheus which intern will be accessed through Grafana Dashboards?
Newbie here…
Thanks
Vikram
Maybe this will help How to scrape grafana internal metrics with prometheus
I had a quick look at our Grafana and the link above seems to have the correct info
# curl http://localhost:8080/metrics
# HELP go_gc_duration_seconds A summary of the GC invocation durations.
# TYPE go_gc_duration_seconds summary
go_gc_duration_seconds{quantile="0"} 2.1466e-05
go_gc_duration_seconds{quantile="0.25"} 4.9953e-05
go_gc_duration_seconds{quantile="0.5"} 7.1067e-05
go_gc_duration_seconds{quantile="0.75"} 9.9476e-05
go_gc_duration_seconds{quantile="1"} 0.002339865
go_gc_duration_seconds_sum 1.2995778150000001
go_gc_duration_seconds_count 15677
Thanks a lot b0b… Let me try to set it up in our environments.
