Hi all, i need some help.
I have stack grafana+loki+promtail and small k8s clester.
Grafana version: 9.1.0
Problem: Whhen i select namespase as filter i dont see all app:
Then when i select missing item, i got error massage:
Empty results, no matching label for {app=“ws-underground-works-public-ui”}
Meaybe someone have idea how to fix this?
PS: Only 2 images for new users, ok =)
Hi @alex2532,
Welcome to the
community forum !!
Can you please share your Loki and Promtail configuration files so that the community members can have a better look?
Thanks
I use separate helm charts(no loki-stack) with default config. I only added
existing pvc(grafana,loki) and config.client.url(promtail). Nothing criminal.
Hi @alex2532,
Thanks for providing more details.
I do not have much expertise when it comes to Kubernets world but I will still try to help you.
We have a documentation page which describes a sample configuration for HELM (Loki + Promtal) to make it working;
Also, found (not exactly) a similar post in our community forum about HELM Charts label issues for loki.
I hope this helps.
