Grafana LDAP error - 11.6
I have upgrade to grafana OSS 11.6 and getting below error while doing LDAP auth: I am using port 636 , anyone faced similar issue: not sure i need to upgrade/install plugins mentioned here:
Sep 04 17:13:47 zgrafana-poc grafana[567877]: logger=context userId=562 orgId=1 uname=TDh001 t=2025-09-04T17:13:47.820468599-04:00 level=error msg=“Could not find plugin definition for data source” datasource_type=xginn8-pagerduty-datasource
Sep 04 17:13:47 zgrafana-poc grafana[567877]: logger=context userId=562 orgId=1 uname=TDh001 t=2025-09-04T17:13:47.820540613-04:00 level=error msg=“Could not find plugin definition for data source” datasource_type=grafana-simple-json-datasource
Sep 04 17:13:47 zgrafana- grafana[567877]: logger=context userId=562 orgId=1 uname=TDh001 t=2025-09-04T17:13:47.820561722-04:00 level=error msg=“Could not find plugin definition for data source” datasource_type=marcusolsson-json-datasource
Sep 04 17:13:48 zgrafana-poc grafana[567877]: logger=context userId=562 orgId=1 uname=TDh001 t=2025-09-04T17:13:48.178539853-04:00 level=info msg=“Request Completed” method=GET path=/api/live/ws status=-1 remote_addr=10.8.221.7 time_ms=24 duration=24.31932ms size=0 referer= handler=/api/live/ws status_source=server <!–
  • What happened?
Hi, where exactly is the LDAP error? From what I can tell you’re trying to load some plug-ins that are (probably) not supported anymore? Do you install with helm chart?
Resolved after upgrade to 11.6.1
