10.2.2
MacOs -
Based on the LDAP groups of a user add the user to organization automatically -
The LDAP config is created, LDAP groups mappings to organizations are in place. Grafana finds user on LDAP server and reads the group to organization role assignment perfectly. -
What happened?
The user is not added to the organization. -
Once the user logs in, LDAP groups are check, the user is automatically added/removed from the organizations mentioned in the group mappings
Followed the LDAP documentation.
Is there any configuration setting I am missing?
