Grafana Jaeger sending remote_addr
Guys,
I am using Jaeger to grab some information from grafana.
For example in the default.ini file, in the section
[tracing.jaeger]
I have something like that
always_included_tag = name:myprojetc-dev
So, I would like to send to Jaeger the “remote_addr” visible on the command line each time a user is logged
logger=context userId=1 orgId=1 uname=admin method=GET path=/logout status=302 remote_addr=122.11.28.137
Is there any way to define that in the grafana configuration file?
Thanks in advance!
