Is it possible to pass query parameter or path variable along with subpath in roo_url grafana.ini configuration?
For Example:
root_url = %(protocol)s://%(domain)s:%(http_port)s:/grafana?customorgId=“1234”
Or
root_url = %(protocol)s://%(domain)s:%(http_port)s:/grafana/customorgId=“1234”
Please suggest how can I achieve this scenario with Grafana.
Thank you for quick response, I am trying to display graphs only for the parameter I will be passing in query.
i.e as per my above example in where clause it would be
And you can access this variable value in your graph panel query using $ symbol, something like this: orgId=$customorgid (this syntax might differ in type datasource or query language you choosing).
