Grafana Influx DB Query
I am trying to create my first query.
The instructions I follow and whats on screen suggest I can select a field and the window looks very different to mine.
Am I doing something wrong?
I follow : Set up Signal K and Grafana on Raspberry Pi with PICAN-M NMEA 2000 board
Welcome @bigalnz
Were you able to get the “green” message at the end of these steps (in your post linked below) that indicate Grafana can connect to your InfluxDB database? I noticed in that post that you chose Flux and the tutorial you linked to indicates you should have chosen InfluxQL.
I did get the green success message with flux. I will double check which I should be picking, but my screens are different at the point where I should be creating the dashboard.
