V9.0.7 and Windows 10 -
Using Telegraf, InfluxDB and Grafana I’m wanting to capture and visualise the Windows performance monitor .Net CLR LocksAndThreads# of current logical Threads against IIS App Pools and have the App Pool names and the # of threads displayed on a graph. -
I’ve imported in the # of current logical Threads counter using Telegraf [inputs.win_perf_counters.object], however this just captures the instances as w3wp, w3wp#1, w3wp#2 etc
As such, I’ve written a Powershell script which obtains the AppPool names for each of those w3wp instances.
The part I’m struggling with is how to use this data to join with the performance counters in order to show a graph with App Pool names and # of threads.
- What happened?
I’m having issues with being able use the second set of data to update the labels
