Windows Exporter User with Alloy - How to get specific processes current count
    Grafana Cloud Platform
    Trying to have a Gauge panel. That shows the process count for 2 specific processes running on an instance.
  • What happened?
    I see the processes gauge but, when i login to the instance, The count is not accurate, as its not current or live, it never seems to match what is happening on the instance “now”.
    The expected result should show the current count of running processes on the instance.
    count by(process) (irate(windows_process_cpu_time_total{instance=~“$instance”, process=~“powershell|GSAWE”}[2m]))
Set to a Time Series Instant or Range gives different results but still not accurate. I’m assuming the query I am using is not quite right, I am not sure on how best to achieve the requirement. Any advice is appreicated.
  • No errors.
  • Did you follow any online instructions? If so, what is the URL? Nothing specific related to my query comes up.
