I am having at hand, a postgres database containing datasets collected some years ago. Here’s how the table looks like.
postgres=# select * from urbansense.new_table;
| recvtime | entitytype | attrname | attrvalue |
| 20014-04-18T12:05:42.00Z | WeatherObserved | illuminance | 20 |
| 20014-04-18T12:05:42.00Z | WeatherObserved | temperature | 15.2 |
| 20014-04-18T12:05:42.00Z | WeatherObserved | relativehumidity | 64.3 |
| 2015-07-10T11:47:02+01:00 | WeatherObserved | illuminance | 29562.7 |
| 2015-07-10T11:47:02+01:00 | WeatherObserved | temperature | 20.7 |
| 2015-07-10T11:47:02+01:00 | WeatherObserved | relativeHumidity | 78.2 |
The goal is to display data points for temperature (attrvalue) on grafana graph panel.
I can retrieve the values (to display on panel using the query below) from postgres client, but grafana shows Data points outside time range only:
postgres=# SELECT DISTINCT
date_trunc('minute', to_timestamp(recvtime,'YYYY-MM-DD HH24:MI:SS')) AS "time",
attrvalue::float AS temperature
FROM
WHERE
attrname = 'temperature'
AND attrvalue <> 'null'
GROUP BY time, urbansense.new_table.attrvalue;
| time | temperature |
| 2015-07-10 07:49:00+00 | 24.1 |
| 2015-07-09 21:18:00+00 | 20.2 |
| 2015-07-09 23:52:00+00 | 19.8 |
| 2015-07-08 23:56:00+00 | 29.1 |
| 2015-07-09 16:02:00+00 | 23.6 |
| 2015-07-09 09:30:00+00 | 32.3 |
| (31037 rows) | |
I tried using the following query from grafana query editor again, (using $__timeFrom() ), grafana displays: No data points
SELECT
COUNT(DISTINCT urbansense.new_table.attrvalue) as time
FROM
WHERE
attrvalue <> 'null'
AND to_timestamp(recvtime,'YYYY-MM-DD HH24:MI:SS') > $__timeFrom()
What is the correct way to display data points within dates available in recvtime column only? I guess grafana is trying to display points in current time (or some few hour ago, so the first error Data points outside time range.
