Grafana graph COUNT MySQL?
Hello All
I’m struggling with displaying a graph from very simple mysql table. There are just three fields: id, date and sensorID - which is equal 1 all the time. Every time an event happens there is a record of it.
date field has datetime type. I would love to display on a graph number of events per day.
I have tried:
SELECT
UNIX_TIMESTAMP(date) as time_sec,
sensorID as value,
sensorID as metric
FROM trigger_tbl
WHERE $__timeFilter(date)
ORDER BY date ASC
where should I put SUM(sensorID) and GROUP BY DATE(date)?
Thanks a lot!
Please use the $__timeGroup macro function. That’s only included in the nightly build right now. If you’re on 4.6.3 or earlier you’ll need to use cast(cast(UNIX_TIMESTAMP(createdAt)/(<seconds>) as signed)*<seconds> as signed) as time_sec, instead.
Taking your example I would use the following query which will return a sum per 24 hours:
SELECT
$__timeGroup(date, '24h') as time_sec,
sum(sensorID) as value,
'Some series/label name' as metric
FROM trigger_tbl
GROUP BY 1
ORDER BY 1
SELECT
cast(cast(UNIX_TIMESTAMP(date)/(86400) as signed)*86400 as signed) as time_sec
FROM trigger_tbl
GROUP BY 1
ORDER BY 1
Also make sure that you select Null Value=Null as zero in display tab if you have days where you don’t have any values.
Please refer to Using MySQL in Grafana documentation for further information.
Marcus
Hi
I use grafana.net online service, when I swapped macro for the cast I got:
Error 1064: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘) as signed) as signed) as time_sec,
’’ at line 2
any clue what is wrong please?
Thank you so much for your support Markcus!
Sorry for that, I’ve updated the post.
Hi
Thank you so much for your support, much appreciate.
The code works, I just need to investigate the discrepancy between the grafana and a google chart I created with query:
SELECT DATE(date) as DATE, SUM(sensorID) totalCount FROM my_database.my_table GROUP BY DATE(date)
Very interesting.
Grzegorz
