Hi we want an alert and alert should tell us if there is any group whose count is below 10.
That is I want the alert summary to show the group name for which the count is below 10
what i want : summary : The count is less than 10 for Pluto
the query I am using to generate alert
select distinct count(*) as cnt,Group from
dataset.tablewhere date(_PARTITIONTIME) = current_date() group by Group
i use B reduce Function last input A, mode strict
C threshold input B is below 10
i see in the preview we get a series below on stats
column below B
Group=Pluto 103
Group=Neptune 20
under column c in preview
Group=Pluto 1
Group=Neptune 1
How do i make the alert so that i can take the values after ‘Group=’ in the summary?
Why in the data under column c preview is changing to 1?
image linkimage of grafana settings
