Hello, I would like to display node graph in my dashboard using ElasticSearch as the data source. I tried to push into an index with this data that was made based on the documentation in Node graph | Grafana documentation
But the thing is, the data is not shown. I am currently using Grafana v9.1.7 and ElasticSearch 8.4.2
This is the sample JSON data that I push to ElasticIndex. Is there any example that I can use?
	"nodes": [
			"id": "node1",
			"title": "Command 1",
			"subtitle": "Subtitle 1",
			"mainstat": "Node1",
			"detail_mitre": "T0000",
			"time": "2022-07-15T05:50:02+0000"
			"id": "node2",
			"title": "Command 2",
			"subtitle": "Subtitle 2",
			"mainstat": "Node2",
			"detail_mitre": "T0001",
			"time": "2022-07-15T05:50:07+0000"
			"id": "node3",
			"title": "Command 3",
			"subtitle": "Subtitle 3",
			"mainstat": "Node3",
			"time": "2022-07-15T05:50:10+0000"
	"edges": [
			"id": "relationship1",
			"source": "node1",
			"target": "node2",
			"time": "2022-07-15T05:50:04+0000"
			"id": "relationship2",
			"source": "node2",
			"target": "node3",
			"time": "2022-07-15T05:50:08+0000"
