Grafana Default Notification policy by Helm Chart
HI,
in my grafana configuration I have 2 “Contact points”:
  • email : present by default
  • teams: set via helm chart
The basic problem is that the default email is set by default in the “Notification policies”:
My goal would be to set as default “Contact points” my channel set by Helm chart (teams):
   alerting:
      contactpoints.yaml:
           apiVersion: 1
           contactPoints:
             - orgId: 1
               receivers:
                 -uid:teams-webhooks
                   is_default: true
                   type: teams
                   settings:
                     url: XXXX
an idea might be to write the “configuration” that is present in the “Admin” section, but I haven’t found anything in the HELM documentation.
do you have any idea about it?
Thanks.
RESOLVED
alerting:
    policies.yaml:
      policies:
        - orgId: 1
          receiver: XXXXXX-teams
          group_by:
          - grafana_folder
          - alertname
I found the solution through the sample.yaml file:
/usr/share/grafana/conf/provisioning/alerting/sample.yaml
Here is the file:
# # config file version
apiVersion: 1
# # List of rule groups to import or update
# groups:
#     # <int> organization ID, default = 1
#   - orgId: 1
#     # <string, required> name of the rule group
#     name: my_rule_group
#     # <string, required> name of the folder the rule group will be stored in
#     folder: my_first_folder
#     # <duration, required> interval of the rule group evaluation
#     interval: 60s
#     # <list, required> list of rules that are part of the rule group
#     rules:
#       # <string, required> unique identifier for the rule
#     - uid: my_id_1
#       # <string, required> title of the rule, will be displayed in the UI
#       title: my_first_rule
#       # <string, required> query used for the condition
#       condition: A
#       # <list, required> list of query objects that should be executed on each
#       #                  evaluation - should be obtained via the API
#       data:
#       - refId: A
#         datasourceUid: "__expr__"
#         model:
#           conditions:
#           - evaluator:
#               params:
#               - 3
#               type: gt
#             operator:
#               type: and
#             query:
#               params:
#               - A
#             reducer:
#               type: last
#             type: query
#           datasource:
#             type: __expr__
#             uid: "__expr__"
#           expression: 1==0
#           intervalMs: 1000
#           maxDataPoints: 43200
#           refId: A
#           type: math
#       # <string> UID of a dashboard that the alert rule should be linked to
#       dashboardUid: my_dashboard
#       # <int> ID of the panel that the alert rule should be linked to
#       panelId: 123
#       # <string> state of the alert rule when no data is returned
#       #          possible values: "NoData", "Alerting", "OK", default = NoData
#       noDataState: Alerting
#       # <string> state of the alert rule when the query execution
#       #          fails - possible values: "Error", "Alerting", "OK"
#       #          default = Alerting
#       executionErrorState: Alerting
#       # <duration, required> how long the alert condition should be breached before Firing. Before this time has elapsed, the alert is considered to be Pending
#       for: 60s
#       # <map<string, string>> map of strings to attach arbitrary custom data
#       annotations:
#         some_key: some_value
#       # <map<string, string> map of strings to filter and
#       #                      route alerts
#       labels:
#         team: sre_team_1
#       isPaused: false
# # List of alert rule UIDs that should be deleted
# deleteRules:
#  - orgId: 1
#    uid: my_id_1
# # List of contact points to import or update
# contactPoints:
#   - orgId: 1
#     # <string, required> name of the contact point
#     name: cp_1
#     receivers:
#       # <string, required> unique identifier for the receiver
#     - uid: first_uid
#       # <string, required> type of the receiver
#       type: prometheus-alertmanager
#       # <object, required> settings for the specific receiver type
#       settings:
#         url: http://test:9000
# # List of receivers that should be deleted
# deleteContactPoints:
# - orgId: 1
#   uid: first_uid
# # List of notification policies to import or update
# policies:
#   - orgId: 1
#     # <string> name of the receiver that should be used for this route
#     receiver: grafana-default-email
#     # <list<string>> The labels by which incoming alerts are grouped together. For example,
#     #        multiple alerts coming in for cluster=A and alertname=LatencyHigh would
#     #        be batched into a single group.
#     #        To aggregate by all possible labels, use the special value '...' as
#     #        the sole label name, for example:
#     #        group_by: ['...']
#     #        This effectively disables aggregation entirely, passing through all
#     #        alerts as-is. This is unlikely to be what you want, unless you have
#     #        a very low alert volume or your upstream notification system performs
#     #        its own grouping.
#     group_by:
#     - grafana_folder
#     - alertname
#     # <list> a list of matchers that an alert has to fulfill to match the node
#     matchers:
#     - alertname = Watchdog
#     - severity =~ "warning|critical"
#     # <list> Times when the route should be muted. These must match the name of a
#     #        mute time interval.
#     #        Additionally, the root node cannot have any mute times.
#     #        When a route is muted it will not send any notifications, but
#     #        otherwise acts normally (including ending the route-matching process
#     #        if the `continue` option is not set)
#     mute_time_intervals:
#     - abc
#     # <duration> How long to initially wait to send a notification for a group
#     #            of alerts. Allows to collect more initial alerts for the same group.
#     #            (Usually ~0s to few minutes), default = 30s
#     group_wait: 30s
#     # <duration> How long to wait before sending a notification about new alerts that
#     #            are added to a group of alerts for which an initial notification has
#     #            already been sent. (Usually ~5m or more), default = 5m
#     group_interval: 5m
#     # <duration>  How long to wait before sending a notification again if it has already
#     #             been sent successfully for an alert. (Usually ~3h or more), default = 4h
#     repeat_interval: 4h
#     # <list> Zero or more child routes
#     routes:
# # List of orgIds that should be reset to the default policy
# resetPolicies:
# - 1
# # List of templates to import or update
# templates:
#   - orgID: 1
#     # <string, required> name of the template, must be unique
#     name: my_first_template
#     # <string, required> content of the the template
#     template: Alerting with a custome text template
# # List of templates that should be deleted
# deleteTemplates:
#  - orgId: 1
# # List of mute time intervals to import or update
# muteTimes:
# - orgId: 1
#   # <string, required> name of the mute time interval, must be unique
#   name: mti_1
#   # <list> time intervals that should trigger the muting
#            refer to https://prometheus.io/docs/alerting/latest/configuration/#time_interval-0
#   time_intervals:
#    - times:
#      - start_time: '06:00'
#        end_time: '23:59'
#      weekdays: ['monday:wednesday','saturday', 'sunday']
#      months: ['1:3', 'may:august', 'december']
#      years: ['2020:2022', '2030']
#      days_of_month: ['1:5', '-3:-1']
# # List of mute time intervals that should be deleted
# deleteMuteTimes:
# - orgId: 1
#   name: mti_1
