Grafana Dashboard Panel Query with join over longer duration timeout
    9.03
    query that uses the service display_name to view process_cpu metrics from windows_exporter
    using a join query (and other similar):
sum((rate(windows_process_cpu_time_total{process!="Idle"}[$__rate_interval])) * on(instance, process_id) group_left(display_name) windows_service_info{display_name=~"$process"}) without (mode,process_id)
  • What happened?
    Panel timeout when time duration is longer like 2 days
    that it works
    net/http: timeout awaiting response headers
    this query was recommended solution from this forum and windows_exporter project
