Hi Team,
I’m new to grafana dashboard, as you all suggest I used the pre-build dashboards for the visualization on Grafana. Is there is way to pull my custom metrics and showed on a panel on the dashboard?
Guide me on this.
Hi @Gerard !
After installing Grafana + influxBD according to this instruction, you will need to use this dashboard, it has a grouping by groups and tags.
Hi @PaulM,
I already set up the Influxdb and Grafana as guided by the office K6 doc. Also, I can find a few preconfigured grafana dashboard that includes the group stats on the dashboard. None of the dashboards show the custom metrics I created example “01_HomePage” as mentioned in the screenshot above.
Guide me to present those custom metrics on the grafana dashboard.
