Hi Everyone,
I seem to be having trouble with Grafana behind an nginx proxy. I’m getting console errors and errors in Grafana, and the changes I try to make in Grafana are not working.
Errors:
From within Grafana I get “Origin not allowed” when trying to access the site from https:// grafana.domainname.dev and making any action.
I see console errors of
this kind whenever i load a page:
Failed to load resource: the server responded with a status of 4030(forbidden) URL: https:// grafana.domainname.dev/public/fonts/roboto/RxZJdnzeo3R5zSexge8UUVtXRa8TVwTICgirnJhmVJw.woff2
Failed to load resource: the server responded with a status of 4030(forbidden) URL: https://grafana.domainname.dev/public/fonts/fontawesome-webfont.ttf?v=4.7.0
this kind whenever i go into submenus or try to make changes (these two errors occur same time as origin not allowed error)
Failed to load resource: the server responded with a status of 4030(forbidden) URL: https://grafana.domainname.dev/api/frontend-metrics
Uncaught (in promise)
"status": 403,
"statusText": "Forbidden",
"data": {
"message": "origin not allowed\n",
"error": "Forbidden",
"response": "origin not allowed\n"
"config": {
"method": "POST",
"url": "api/frontend-metrics",
"data": {
"events": [
"name": "frontend_boot_first-paint_time_seconds",
"value": 1.045
"name": "frontend_boot_first-contentful-paint_time_seconds",
"value": 1.045
"name": "frontend_boot_load_time_seconds",
"value": 1.311
"retry": 0,
"headers": {
"X-Grafana-Org-Id": 1
"hideFromInspector": true
Grafana Config:
General Configuration:
instance_name = grafana.domainname.dev
Server block:
[server]
# Protocol (http, https, h2, socket)
;protocol = http
# The ip address to bind to, empty will bind to all interfaces
;http_addr =
# The http port to use
;http_port = 3000
# The public facing domain name used to access grafana from a browser
domain = grafana.domainname.dev
# Redirect to correct domain if host header does not match domain
# Prevents DNS rebinding attacks
;enforce_domain = true
# The full public facing url you use in browser, used for redirects and emails
# If you use reverse proxy and sub path specify full url (with sub path)
root_url = https://grafana.domainname.dev/
# Serve Grafana from subpath specified in `root_url` setting. By default it is set to `false` for compatibility reasons.
;serve_from_sub_path = false
Everything else is unaltered, except for mail settings I set further down. When i try to turn on enforce_domain it ends up in a redirect loop and the browser can’t connect.
NGINX Config:
/etc/nginx/sites-available/grafana.domainname.dev :
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
server {
root /var/www/grafana/html;
index index.html index.htm index.nginx-debian.html;
server_name grafana.domainname.dev www.grafana.domainname.dev;
location / {
proxy_pass http://localhost:3000/;
location /api/live {
rewrite ^/(.*) /$1 break;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
proxy_set_header Host $http_host;
listen [::]:443 ssl ipv6only=on; # managed by Certbot
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/grafana.domainname.dev/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/grafana.domainname.dev/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
if ($host = grafana.domainname.dev) {
return 301 https://$host$request_uri;
} # managed by Certbot
listen 80;
listen [::]:80;
return 404; # managed by Certbot
Some of the above was added by certbot, and i didn’t touch any of that, and I tried to follow grafana’s tutorial as well as some forum suggestions but to no avail!
/etc/nginx/nginx.conf :
user www-data;
worker_processes auto;
pid /run/nginx.pid;
include /etc/nginx/modules-enabled/*.conf;
events {
worker_connections 768;
# multi_accept on;
http {
default upgrade;
'' close;
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# server_names_hash_bucket_size 64;
# server_name_in_redirect off;
include /etc/nginx/mime.types;
default_type application/octet-stream;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
access_log /var/log/nginx/access.log;
error_log /var/log/nginx/error.log;
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript;
# Virtual Host Configs
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/sites-enabled/*;
This is all standard except I did add the map $http_upgrade part however that doesn’t look to have done anything.
If anyone has any insight here, I’d really appreciate it! It looks like something isn’t making it back to localhost:3000 however I’m not sure why/hows that is possible when nginx is configured to send everything from grafana.domainname.dev to localhost:3000. Appreciate the help in advance!
I’m assuming this is just a config error, but if logs are needed just let me know which ones and I’m happy to provide them!
