Grafana compatibility with workflow canvas
I want to integrate Grafana with workflow canvas tool What are the steps Is it compatible tool to integrate with grafana?
not sure of one that is out of box but checkout the business text plugin where you can do the following if you are comfortable using javascript.
Is there a workflow canvas js library you know of? maybe jsplumb or …
or maybe use mermaid if the workflow canvas generates mermaid data
workflow canvas is tool like nodered recently offered by siemens its not any plugin
