We have been using Grafana Kiosk for a while and everything used to be working fine up until recently. If you use Grafana Kiosk to open a Dashboard or Playlist directly it will not actually open anymore.
I expect that the problem is because when the Grafana Kiosk actually logs in it does not get redirected back to the page you originally came from. You will always get redirected back to the overall dashboard view of Grafana.
I was able to reproduce the same issue when you open any dashboard URL directly in the browser.
Get redirect to https://$ACCOUNT.grafana.net/login
Press the button “Sign in with Grafana”
Sign in on https://grafana.com/auth/sign-in
You’ll be redirected toward https://$ACCOUNT.grafana.net/?orgId=1
Are there other people who experience the same issue or have a solution for the problem I’m facing? If not, it would be great if the previously working scenario could be reintroduced
I am experiencing the same behavior: Since a few days grafana-kiosk is always ending up on the “welcome-dashboard”, instead of the passed dashboard. Was there any outcome in the mentioned support ticket?
