Grafana:change the role of an existing user
I have created few Grafana users using curl command. Here is the command i used.
> Blockquote
curl -XPOST -H "Content-Type: application/json" -d '{
  "name":"user1@graf.com",
  "email":"user1@graf.com",
  "password":"userpassword",
  "role": "Admin"
}' http://admin:admin@grafana01.default.svc.cluster.local:3000/api/admin/users
> Blockquote
Now i want to change the role from **Admin** to **Viewer** . How can i do that?. is there any other way I can try this out?. Any help is appreciated?
Thanks
shak
It should be possible to edit this under shield/users
Thanks. i wanted to edit using curl command. how can it achieve that?
i had a look with wireshark how it works from te UI.
I can change the email address with:
curl -XPUT -H “Content-Type: application/json” -d ‘{
id":9,“email”:"userY6MD@graf.com
}’ http://admin:xxxxxxxxx@192.168.1.154:3000/api/users/9
So no “admin” in HTTP call at the end.
The userid (in this case 9) you get when you create the user.
Did not get all the users + id’s with curl. In wireshark i see:
role is changed with a “form”, did not try this but probably possible with curl.
Hope you get a bit further with this,
I am not a grafana specialist, just using it for a couple of days. So maybe there is a easier way :).
success
If anyone else is looking for how to create a user in code (like I did when deploying Grafana with Helm in Kubernetes):
curl -XPOST -H “Content-Type: application/json” -d ‘{ “name”:“Name”, “login”:“name”, “password”:“$pass”, “orgId”:1 }’ http://$GF_SECURITY_ADMIN:$GF_SECURITY_ADMIN_PASSWORD@localhost:3000/api/admin/users;
You can also change the role:
curl -XPATCH -H “Content-Type: application/json” -d ‘{ “role”:“Editor”}’ http://$GF_SECURITY_ADMIN:$GF_SECURITY_ADMIN_PASSWORD@localhost:3000/api/orgs/1/users/2;
