Grafana backend server proxy
As we develop a new plugin, we noticed that we could use Grafana as a proxy in order to query a datasource to which only Grafana has access to (for example the same server where grafana is installed)
We would need to use this proxy functionality in order to call a REST service that is restricted. Is there a possibility to set the proxy option to the backend server ?
Or, more specifically we need to find a way to make Grafana retrieve some SNMP information which should be used in the panel titles. Do you see any possibility to make Grafana call a system command, for example a python script ?
Thanks you for your time, any feedback would be greatly appreciated.
If you have a http api, a plugin can call it via the data proxy.
Grafana does not do SNMP. You need to write a custom datasource plugin that calls your http service
Hi, thanks for your answer. The problem is that we need to perform some POST requests as well (for provisioning a new equipment) and from what I have noticed using the data source limits my API calls to a few GET requests. So it looks I can’t use a datasource, is there a way to use the proxy directly in the plugin without messing with the datasource type plugins ?
In other words, how do i call the REST api from the plugin using the data proxy but without using a datasource type plugin ?
Thank you
You have to write a custom datasource plugin, then you can do what ever http calls you like
ok, thanks for your answer. I wil try that
I’m trying to make this but every time I test I have this error :
Failed to load resource: the server responded with a status of 503 (Service Unavailable)
on this line : fetch(input, perSubscriberInit), file : fetch.js
Did someone know how to fix it ?
