Unfortunately I can’t help you with the nginx configuration, I don’t use the helm chart myself, hopefully someone else can chime in. You may also want to post on the community slack and see if anyone there can help you out.
thanks,
changed that as well and still same issue persistent, except fixed all errors from loki and alloy…i’ll give you an example…
pod-1 is continuously printing logs. loki will show them for a while and then just stop…without any error, then when i restart the alloy pod pertaining to pod-1 it will flush data from it and i will see the logs on loki again but only one flush and stop again, and it will be of the past 3 days or something, even though max_chunk_Age is 4h…alloy groups together the logs from 3 days ago or more into a timestamp that is of a new log and thus it is able to push it without beign “too far behind”.
and its usually a select number of pods that do this…
