Grafana Alloy for Low Badwith environments
Hi everyone,
I’m currently evaluating Grafana Alloy for a fleet of edge devices (primarily vessels) where network conditions vary significantly between deployments. Some edges have stable, high-bandwidth links, while others rely on satellite or intermittent connections with highly fluctuating bandwidth, latency, and packet loss.
While looking at the otelcol.processor.batch configuration, I noticed that the batch parameters are statically configured. This means the same send_batch_size is used regardless of the network conditions experienced by a particular edge.
For example:
  • Vessel A: 100 Mbps stable connection → larger batches are efficient.
  • Vessel B: 20 Mbps connection → moderate batch size works well.
  • Vessel C: Satellite connection with fluctuating bandwidth and intermittent connectivity → large batches can increase retries, queue buildup, and export latency.
Reducing the batch size globally helps slower links but also increases request overhead for well-connected edges.
This made me wonder whether an adaptive batching capability would make sense.
Proposed idea
The idea would be an optional adaptive mode that dynamically adjusts the effective batch size at runtime based on exporter health rather than relying on a fixed configuration.
Rather than using only bandwidth, the controller could observe metrics such as:
  • Export latency
  • Retry rate
  • Consecutive failures
  • Sending queue utilization
  • Export success rate
  • Flush duration
  • Other exporter metrics already exposed by Alloy/OpenTelemetry Collector
The controller could then:
  • Increase the batch size gradually when exports are healthy.
  • Reduce the batch size quickly when retries, latency, or queue pressure increase.
  • Use hysteresis or moving averages to avoid oscillations.
Something conceptually similar to:
otelcol.processor.batch "default" {
  send_batch_size = 8192
  adaptive {
    enabled = true
    min_batch_size = 500
    max_batch_size = 10000
    evaluation_interval = "30s"
If adaptive is not configured, the existing behavior would remain unchanged.
Questions
Before I start working on a proof of concept, I wanted to ask the maintainers:
  1. Has this idea already been discussed or attempted?
  2. Is there an existing roadmap item for adaptive batching or adaptive flow control?
  3. Since Alloy wraps the OpenTelemetry Collector, would this functionality be more appropriate in the upstream OpenTelemetry Collector batch processor rather than Alloy itself?
  4. Are there any architectural concerns that would make this approach unsuitable?
  5. Would maintainers be open to reviewing a proposal or proof of concept if the design aligns with the project?
My goal is to contribute something that is useful for edge and intermittently connected deployments while remaining fully backward compatible.
I’d appreciate any feedback or guidance before I start implementing it.
We have a similar case, Alloy running on vessels with satellite links and on sites with good links, all managed by Fleet Management.
I don’t think there is an adaptive batch today, but you can avoid one static config for all. With Fleet Management each collector has attributes, so you can add one like link=“satellite” and create a separate pipeline for these collectors with smaller batches and more retries, and another one for the good links. Each vessel gets the right config and you change it in one place.
For metrics we use prometheus.remote_write and not OTLP. It writes to a WAL on disk first, so when the link drops the data stays on the vessel and is sent when it comes back (up to max_keepalive_time, default 8h). Then we tune the queue_config, in our case capacity 10000 and max_samples_per_send 2000, and scrape every 60s, that already reduces a lot the traffic.
If you stay with OTLP, look also at compression (zstd is better than gzip on slow links) and at retry_on_failure and sending_queue in the exporter.
The adaptive idea is good, I would open it as a feature request in the grafana/alloy GitHub so the team can see it.
Regards,
Igor
